Refrigerator Power-ON Delay; PIC timer
Offline ネ㑟㑯㑠
  • 4216
  • 134
Re: Refrigerator Power-ON Delay; PIC timer
« Reply #40 on: December 29, 2013, 09:44:18 PM »
saka cmos kasi yong sardinas maypagka sensitive ito, baka pag-inilagay sa aircon na 1hp magtrigger eto kada "on" ng aircon? baka maloka yong may-ari  ;D ;D ;D
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #41 on: December 29, 2013, 10:04:36 PM »
Mas "off" ang trigger sis. Actually meron time delay para sa mga ganyan na gamit. Coated ng epoxy resin. Ayaw ipagaya siguro.  :)
Nako OT na yata.
FISH
Offline alyas
  • 3119
  • 211
« Reply #42 on: December 29, 2013, 11:05:16 PM »
tanong ko lang, if relay ang gamit to switch, importante pa ba ang zero cross detection?  or for simple on off switch lang?  kailangan lang ba tong zero cross detection if triac ang gagamitin?
Offline akosiikem
  • 462
  • 6
« Reply #43 on: December 30, 2013, 12:12:29 AM »
0 crossing sa thyristor lang yun di na applicable sa relay
"Take chances! Make mistakes!"
             - Mrs. Frizzle(Magic School Bus)
Offline Super zHero
  • 5833
  • 310
« Reply #44 on: December 30, 2013, 02:54:16 AM »
Ang relay kasi meron pang contact bounce.  It takes a few milliseconds for it to settle, kaya wa-effect ang zero-crossing.
Offline µAudio
  • 270
  • 43
« Reply #45 on: December 30, 2013, 07:18:48 AM »
we done it using PIC16F1708
Offline Super zHero
  • 5833
  • 310
« Reply #46 on: December 30, 2013, 09:09:33 AM »
I looked at PIC16F1708, built-in zero-crossing detect on a 20-pin IC.
Wala sa RS or Element14.
Offline tranqspogi
  • 392
  • 50
  • Sabi ng MAMA ko POGI daw ako. kaya panindigan ko!
« Reply #47 on: December 30, 2013, 10:43:17 AM »
wala po bang simple jan? pag PIC kasi walang available sa amin
***Homemade 12v inverter lamp, CLF even the Angel eye*** http://www.elab.ph/forum/index.php?topic=41841.0
***30 watts amplifier 12volts*** http://www.elab.ph/forum/index.php?topic=45220.new#new
***44 watts amplifierr 12volts*** http://www.elab.ph/forum/index.php?topic=45712.0
***Modified Servo SG90*** http://www.elab.ph/forum/index.php?topic=50149.0
Offline ネ㑟㑯㑠
  • 4216
  • 134
« Reply #48 on: December 30, 2013, 10:58:20 AM »
yong pinakamabilis na response time ng relay ay nasa mga 8 to 50ms from energizing the coil to contact closure. ang powerline natin ay 60hz meaning ang one cycle nito ay 16ms at ang peak voltages occurs every 4ms. kahit e switch natin sa zero crossing yong coil ng relay ang contact nito ay pwedeng mag-close sa peak ng line voltage.
whereas sa triac nanosecond ang respond time nito from bias to conduction kaya pwedeng ipa trigger ito sa zero crossing dahil sa bilis nito mismong sa zero crossing talaga ito mag-conduct.
Offline Super zHero
  • 5833
  • 310
« Reply #49 on: December 30, 2013, 11:54:24 AM »
How simple do you want  ???
555 circuit mas available ang parts.  Check mo yung kabilang thread.  Mas marami lang parts at hindi Flip/Flop ang output.  Wala rin audible & blinking LED warning.
http://www.elab.ph/forum/index.php?topic=40745.msg761847#msg761847
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #50 on: December 30, 2013, 02:37:25 PM »
Lagyan na lang ng buzzer then decade counter tapos led.  ;)
FISH
Offline Super zHero
  • 5833
  • 310
« Reply #51 on: December 30, 2013, 05:46:58 PM »
... pag PIC kasi walang available sa amin
Wala rin PIC available dito sa amin.  Mga PIC ko order ko pa sa RS-online.com ata
Offline Super zHero
  • 5833
  • 310
« Reply #52 on: March 14, 2014, 11:27:40 PM »
Update:
  It works as in the schematics on post #1 and I used a transformerless PS.  The Triac is a Q6008RH4, 600V 8A.  No considerable heat on the Triac with no heatsink, just slightly warm with 60W bulb load.  Wala kasi akong higher load for this "dry run" and I don't want to plug in the ref just yet while I'm characterizing the circuit.
My ref is about 135W.  I'll be happy if I won't need a heatsink for this.  My next version I will try to do away with the optocoupler and do the zero crossing algo on the PIC itself.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #53 on: March 14, 2014, 11:32:24 PM »
Abang lang sir Z.
FISH
Offline Super zHero
  • 5833
  • 310
« Reply #54 on: March 14, 2014, 11:48:47 PM »
Here's the PS section.  Reminder again that this is NON-ISOLATED and DANGEROUS ! ! !
Once in use, there should not be any access to the circuit.
This PS has enough current for the PIC, LED and opto.  CR3 gives out 4.9V and you might want to use 1N4734 to up the voltage a bit.  But it still works fine.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #55 on: March 14, 2014, 11:53:20 PM »
I recommend a good brand component para sa ps lalo na sa diode.
FISH
Offline Super zHero
  • 5833
  • 310
« Reply #56 on: March 15, 2014, 12:01:43 AM »
Kailangan ko pa i-test yung circuit ng "AC drop-out" kung magre-reset yung PIC.
I have to device an SSR to turn off for some AC cycles. (just thinking aloud).  Or maybe just drop C2's value just enough to filter the DC but not hold it once the AC drops out a few cycles.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #57 on: March 15, 2014, 12:04:19 AM »
Mukha ngang kunting sakripisyo sa filter cap sir mga 10-100uf lang sir. Kapag lumaki pa siguro dyan sir ng kunti baka hindi niya mahhuli yung ac drop out.
FISH
Offline Super zHero
  • 5833
  • 310
« Reply #58 on: March 15, 2014, 12:07:53 AM »
Oo, sisilipin ko muna sa O-scope kung anong hitsura ng DC.  Baka 47uF magkaari na.  Yan, gagawa pa ako ng isolation xfmr  >:(
  • 6597
  • 312
« Reply #59 on: March 15, 2014, 10:37:25 AM »
nung nagtest ka ba ng temperature ng triac, nakaisolate ka na? I was wondering kasi kung di pa... how di you check it? ... by touching? ;D
