PioNeeR SX_770
  • 11484
  • 872
PioNeeR SX_770
« on: March 17, 2014, 07:46:21 PM »
in another thread i posted this:
if you like the sound of the Pioneer SX 770, circa 70's,
we are coming up with a DIY thread very soon,
the amp build will feature a phono stage, a tone control stage,
and a power amp stage using today's available trannies,
it will be a good build for the newbie,
not so expensive on parts and very easy to make..
watch out for it...
i built this amps in 1976 and i remember that it sounded really nice..
http://elektrotanya.com/pioneer_sx-770_sch.pdf/download.html
with the kind assistance of Willy, i would like to offer this to newbies
as a starting project, minus the tuner and mpx sections,
like i mentioned, this amp is nostalgic, i made a lot of this in the 70's...
i was able to scale this amp with rails as low as 36 volts to as high as 80 volts...
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #1 on: March 17, 2014, 07:51:35 PM »
some pictures of the amp i made in 1976....
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #2 on: March 17, 2014, 07:54:49 PM »
block diagram...
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #3 on: March 17, 2014, 07:56:56 PM »
phono stage...
tone control stage...
power amplifier stage...
Offline crazyzai
  • 144
  • 14
Re: PioNeeR SX_770
« Reply #4 on: March 18, 2014, 01:49:11 AM »
ayos to way back to 80s meron daw daddy ko nito noon kasama ng radiopono  (turntable) malakas daw to parang mga component  ;D ;D ;D pa abang po ako
Offline cyrusnicole
  • 1293
  • 83
  • WORK LIKE A SLAVE.....DRINK LIKE A KING..!!!!!
Re: PioNeeR SX_770
« Reply #5 on: March 18, 2014, 09:10:50 AM »
balatan na ang sibuyas sir tony..nangangamoy na ito bagong luto...adobo... ;D ;D ;D ;D.....
basta pioneer maganda tunog ;) ;) ;)
work like a slave...drink like a king   :)
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #6 on: March 18, 2014, 09:35:22 AM »
this is the power amp pcb...
this is the tone control pcb...
this is the phono pcb..
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #7 on: March 18, 2014, 09:36:02 AM »
this is an attempt to bring bak the sounds of the 70's....
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #8 on: March 18, 2014, 09:40:28 AM »
the original amp used a B+ of 48 volts, this amp board will give you options,
the other one is 84 volts for greater power, should one desire it.....
i used this amp with rails of only 36 volts and was quite happy with it...:D
for the 84 volt versions, TIP35C or similar  will be used
while for the 48 volt version, TIP41C...
i will explain design changes for the 84 volt version...
Offline mc_king
  • 264
  • 28
Re: PioNeeR SX_770
« Reply #9 on: March 18, 2014, 09:46:06 AM »
paabang....
Offline James_T
  • 157
  • 13
Re: PioNeeR SX_770
« Reply #10 on: March 18, 2014, 09:48:51 AM »
wow nice one...   kapamilya ng SX-440 namin dati.  hehehe  ;D ;D ;D
pa sub..
Offline cyrusnicole
  • 1293
  • 83
Re: PioNeeR SX_770
« Reply #11 on: March 18, 2014, 09:49:33 AM »
ay anbilis maluto.. ;D ;D ;D
ilalagay ko muna ito sa collection ko ...waiting ako sa working board
 waiting din sa file para download ;D ;D ;D
Offline ricdelros
  • 933
  • 117
Re: PioNeeR SX_770
« Reply #12 on: March 18, 2014, 10:22:32 AM »
Ayus yan, mas gusto ko tunog ng 70's. :)
Offline djkingchristian
  • 1881
  • 137
  • more projects to do
Re: PioNeeR SX_770
« Reply #13 on: March 18, 2014, 10:35:36 AM »
pa sali po
Offline jiggins20
  • 797
  • 34
Re: PioNeeR SX_770
« Reply #14 on: March 18, 2014, 11:15:07 AM »
sali din ako...share na ang pdf sir...
Audio amp addict
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #15 on: March 18, 2014, 11:22:20 AM »
transformer requirements...
for the  48V rails, we have 32wpc into 8 amp....
a traffo capable of about 150VA is needed
secondary voltage is around 35 volts ac,
since we are using a 63volt cap, the rails can be 40 to 50 volts,
value is not that critical....
for the 85 volt rail amp, we have a 100wpc at 8 ohm amp...
a traffo capable of 400VA is needed...
we will be using at least a  10000ufd/100vdc ecap,
traffo secondary required is around 60 volts,
a center tap is needed, so that we need a 30-0-30 volts ac secondary
i will explain later why?
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #16 on: March 18, 2014, 11:26:17 AM »
we are working on the power supply board, Wiljj78 designed all boards used here,
he will upload the pdf of the layout and then you can bring out your plantsa's and start
making the boards....
Offline whitenoize18
  • 220
  • 19
Re: PioNeeR SX_770
« Reply #17 on: March 18, 2014, 12:22:04 PM »
sali din ako dito,  :D
Before God we are all equally wise - and equally foolish.---Albert Einstein
Offline Wiljj78
  • 209
  • 121
Re: PioNeeR SX_770
« Reply #18 on: March 18, 2014, 01:17:06 PM »
Sir tony,
Files for this projects are now ready to download, Enjoy.....
http://www.4shared.com/rar/SGi1WS5gba/PIONEER_SX-770_Amplifier.html
http://www.4shared.com/rar/wsKNUxw2ce/PIONEER_SX-770_Tone_Control.html
http://www.4shared.com/rar/Mm1F3BK4ba/PIONEER_SX-770_Head_Amp.html
PSU board is underway......
  • 11484
  • 872
Re: PioNeeR SX_770
« Reply #19 on: March 18, 2014, 01:32:54 PM »
thank you very much Willy....emailed you the complete scheme...
here is the psu design...please make room around the 317 for a heatsink if needed...
