Clean out grounding design
  • 11484
  • 872
Re: Clean out grounding design
« Reply #60 on: December 18, 2014, 03:54:00 PM »
5 ohms na ang standard ng meralco as many of their electronics need that level of resistance. hindi lang dapat sa substations, dapat sa lahat ng buildings ei ganyan ka stringent ang requirements
is that for the rod only or system?
the 10 ohm i quoted is for rod only buried into the ground and without anything connected to it...
in cases where the resistance is higher, then couplers are used to add length,
a rod usually measured 1.5 meters long and has a diameter of 16 mm,
i am not familiar with local practice though...
on one installation i worked on in Singapore, there were more than 500 rods all interconnected
using 120mm, 70 mm squared grounding wires....
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #61 on: December 18, 2014, 04:20:51 PM »
Ground rod pa lang  ulam na.
Satin electrical installation na, gusto magik pa.
FISH
Offline <<<<<------
  • 1025
  • 38
« Reply #62 on: January 04, 2015, 11:45:39 PM »
i wish i could post drawings and plans for grounding in the plants that i worked on...
yes, they are completely separate....but like i said, they meet at the ground where earth rods are buried for both dirty and clean earths in close proximity to one another....
usually ground separation distance is equal to the lenght of ground rod or ground matting surface area. make it twice to be safe.
Offline aldwin
  • 551
  • 7
« Reply #63 on: May 27, 2015, 08:12:13 AM »
,,,,hindi, meron dalagita na pumapasok sa banyo  ::)
bakit ngayon ko lang nabasa ito?    wahahahahahaha
