UAV, UAS unmanned systems
Online Super zHero
  • 5811
  • 310
Re: UAV, UAS unmanned systems
« Reply #40 on: July 28, 2015, 01:40:33 PM »
I just opened this topic.  On the very first post, the fixed wing has a 100L tank while the helicopter has an 80L tank.  Geeez,,, my pick-up truck only has a 75 liter tank!  :-[   Tama ba yon?
Offline <<<<<------
  • 1025
  • 38
« Reply #41 on: July 28, 2015, 02:28:28 PM »
100km yata ang range, pabalik another 100km. mga 2km/L ang konsumo, lifter + thrust.
Offline highside
  • 114
  • 11
  • Life is what you make it.
« Reply #42 on: July 28, 2015, 02:36:38 PM »
yes correct 100L yung fix wing. MTOW is 160kg. halos galing sa engine pa punta sa guhit cowling ng fuselage puro fuel tank yan.ang helicopter 40Litters on each side. over power yan sa 300cc. halos half throttle lang yung engine umaangat na yang heli. ang rotor blade design ang sekreto. ang blade is $10k a piece. made by people na gumagawa ng parts for bell jet ranger halicopters.
Offline <<<<<------
  • 1025
  • 38
« Reply #43 on: July 28, 2015, 02:38:34 PM »
papaano po ba ang measure ng fuel comsumption ng isang aircraft?
Offline highside
  • 114
  • 11
« Reply #44 on: July 28, 2015, 02:41:18 PM »
cruise speed is around 150km/hr so 100km is nothing para sa eroplano na yan. ang fuel burn is 1 1/2 to 2 liters an hour at cruise if my memory serves me right
Offline <<<<<------
  • 1025
  • 38
« Reply #45 on: July 28, 2015, 02:45:19 PM »
hindi ba nakaka-apekto sa flight pattern ng uav ang galaw ng fuel nito saka yong weigth nito? papaano ninyo e compensate ito?
Offline highside
  • 114
  • 11
« Reply #46 on: July 28, 2015, 02:45:46 PM »
yung engine my sariling ECU. altitude compensated ang fuel mixture. bale my onboard barometric sensor ang engine para sa altitude tapos mag automatic mag adjust ang Fuel mixture based sa altitude. my onboard sensors din para mag measure kung ano ang fuel burn based on  all RPM range. kaya alam namin kung ilan oras ang lipad bago pa umalis ang eroplano sa ground. tapos lagi naka relay sa ground station lahat data ng engine. RPM, Cylinder head temp, Fuel burn, EGT, generator power.
Offline highside
  • 114
  • 11
« Reply #47 on: July 28, 2015, 02:48:32 PM »
if familiar ka sa buffer sa loob ng fuel tank. that's solves the problem yung gumagalaw ang fuel. hindi one piece ang tank.
Offline <<<<<------
  • 1025
  • 38
« Reply #48 on: July 28, 2015, 02:52:25 PM »
katulad din pala ng tanke ng sasakyan panlupa.
sir, matanong ko di ba yong manned aircraft ay may guide na awac's ano ang katumbas nito sa uav's.
don kasi sa movie na furious 7 pinalipad yong predator mula sa in-flight na chopper tapos nandon narin yong control ng uav predator. malayo siguro sa totoo yong movie pero mas lethal yong paraan, kamuntik ng mamatay yong bida hihihi..
Offline highside
  • 114
  • 11
« Reply #49 on: July 28, 2015, 03:03:28 PM »
pwede kung naka SAT-COM ang UAV. pero wla pa ako nakita. na nasa chopper ang control. meron sa Van or barko. usually ang problema sa van is yung terrain usually naka tracking antenna kami para ma cover yung 100km or 50km. sa onboard antenna is usually blade antennas sa ground is parabolic grid around 24db gain. on board nasa mga 6db to 9db gain lang. pag natakpan ng kahoy or bundok lagot. rare ang operation na moving din ang ground station. very very rare.
Offline <<<<<------
  • 1025
  • 38
« Reply #50 on: July 28, 2015, 03:10:29 PM »
gaano po ba kalaki ang control ng isang uav? ano po ba ang computer nito pc din po ba? anong os po gamit sa mga ganito? isang uav isang control van po ba? may didekitid for sale software po ba ito? o kayo na mismo ang nagdevelop? ano po tawag sa apps na ganito?
Offline highside
  • 114
  • 11
« Reply #51 on: July 28, 2015, 03:15:02 PM »
meron din movie na meron UAV. kung nakita nyo yung movie na "the interview" yung sa north korea. meron UAV na ginamit pang deliver nong poison. ang name nong UAV na yun is Scan Eagle ng Insitu (hindi 22o na my after burner yang UAV na yan. hahahahahhaa) search nyo sa google. Insitu is owned by boeing. binili nila pero sa pag kakaalam ko binibenta ulit ng boeing so kung cno my pera dyan bilhin nyo na. napaka ganda ng Scan eagle ang service nyan sa iraq at Afghanistan sa number of hours in service halos pareho ng predator.
so far ang scan eagle ang pinaka practical at napaka bilis ang time to deployment na UAV. Patented nila ang recovery system which is very effective sa maritime environment.
scan eagle was originally designed para sa mga mangingisda yung nag hahanap ng school of fish. fisherman yung original na gumawa e. ginawa lang yang scan eagle sa garahe tapos nakita ng military ang potential ginawang pang military. nagalit yung original na developer binenta ang shares. yun ang sa pag kakaalam ko.
Offline <<<<<------
  • 1025
  • 38
« Reply #52 on: July 28, 2015, 03:21:56 PM »
nabasa ko dito parang si congressman yata isa sa bida don sa movie sabi ni frogman  ;D ;D ;D
joke lang po, di ko po nakita yong movie.  :)
ang ganda pala ng estorya ng scan eagle uav.
Offline highside
  • 114
  • 11
« Reply #53 on: July 28, 2015, 03:23:26 PM »
isang PC lang ang control ng UAV marami lang ang monitors. pwede nga sa raspberry pi mo patakbuhin. OS majority windows kung java based Linux ang OS. usually ang software ng UAV bundled ng Hardware typically. meron din iba binibenta lang nila is Software lang kayo na bahala mag integrate ng hardware.
sa military kasi masyado clang particular sa IP(intellectual property) usually gusto nila kanila yung IP. which hindi pwede pag binili mo yung Software (obviously). so you end up gumawa ng sariling GCS. hindi namn mahirap gawin. matatapos mo gawin ang GSC within a month lang basta completo na ang command protocols.
wlang Ground control station na parang IRON man style. Flat colors usually kasi sa eye strain ng pilot in command. masakit sa mata ang masyadong maraming ngyayari sa screen na hindi kailangan lalo na pag long operations. hindi practical ang ginagawa ni IRON man. Grey black green at red lang usaully ginagamit na color.
Offline <<<<<------
  • 1025
  • 38
« Reply #54 on: July 28, 2015, 03:31:41 PM »
nakakita na po ako ng wan na scada ganyan din po ang kulay ng mga monitor nila, para sa mata pala nila yon.
ano po ba ang mga importanteng data na e monitor sa isang nagpapalipad ng uav? ilang monitor screen po ba dapat?
pindot ako ng pindot ng points para sa inyo sir pero di na daw pwede.
Offline highside
  • 114
  • 11
« Reply #55 on: July 28, 2015, 03:40:27 PM »
ano po ba ang mga importanteng data na e monitor sa isang nagpapalipad ng auv?
GPS Health = ex. number of sat., HDOF, yung HDOF (kung tama ang abbreviation ko). yan nag determin kung gano ka accurate yung gps mo correct me if im wrong. pero marami ang neglect to na data sa NEMA ng GPS. rule of thumb bellow 2 is good above 3 is bad. typical 1.5 to 2.
IMU health = makikita mo artificial horizon. pero pag nag fail ang IMU wla ka na magagawa crash na tlga.
Propulsion system data = either electric powered or combustion engine.
Coms system =  pag wlang com. ma tataranta na. kasi baka di na maka uwi ang airplane. and kung ma crash man di mo alam saan di na ma recover.
pag medyo mahal ang gamit naka lagay usually 3 or more ang Autopilots na onboard hindi isa lang. redundancy. if you are familiar of Voting Algorithm ganyan mag switch from one system to another. :)
Offline <<<<<------
  • 1025
  • 38
« Reply #56 on: July 28, 2015, 03:46:38 PM »
tig-iisang screen po ba yan? gps, imu, ice, comm monitors? bale apat na screen sa isang pc? o gamit din kayo ng multiple pc server?
pwede po ba e switch from one point controller to other point controller ang isang in-flight uav? i mean from one location to another location na controller.
Offline highside
  • 114
  • 11
« Reply #57 on: July 28, 2015, 03:52:15 PM »
tig-iisang screen po ba yan? gps, imu, ice, comm.
hindi namn kasi dapat minimum yung eye movement ng pilot para hindi ma hilo. "scanning" ata ang term yung mag glance ka lang sa lahat ng instrument mo para ma monitor mga sensor readings. usually ang naka hiwalay na screen Non-critical data ex. temperature outside at inside temp. fuel guage. RPM. kasi meron mga automatic na emergency trigger namn. yung camera video Feed galing sa front camera at gimbal camera. usually 2 to 3 monitors gamit.
mga critical data nasa front tlga ng pilot. RSSI, artificial horizon, mapa RPM GPS health. etc
pero di pa ako naka naka operate na naka SWARM ang UAV. di pa kami umabot sa Swarm. multiple UAV sa isang Ground control.
Offline <<<<<------
  • 1025
  • 38
« Reply #58 on: July 28, 2015, 03:57:38 PM »
nakatotok lang pala sa flight data yong controller. check lang niya status ng uav at comm sa side screen.
anong po bang klaseng wireless comm data signal transmission po ba ang gamit dito?
Offline highside
  • 114
  • 11
« Reply #59 on: July 28, 2015, 04:01:46 PM »
anong klaseng data signal transmission po ba ang gamit dito?
i cant tell sa data transmission its classified pasensya na. pero meron 128-256AES encryption lahat ng transmission lines yan lang masasabi ko.
for commercial or civilian use yung Digi Xtend will do. naka spread spektrum ata yun at frequency hopping.meron din iba pero di ko na try.
