APC BacpUPS ES 500
Offline shiloh
  • 34
  • 0
APC BacpUPS ES 500
« on: August 15, 2015, 09:01:43 AM »
Hello mga Master Paturo lang po sana ako kasi yung APC ES 500 na UPS ko nagcocontinue beep nalang, ok naman po ang Battery. Anong parts po kaya ang dapat palitan kung meron man? Salamat po in Advance.
Offline Super zHero
  • 5837
  • 310
Re: APC BacpUPS ES 500
« Reply #1 on: August 15, 2015, 12:27:54 PM »
Kalimitan meron pang sapat na voltage ang battery pagsinukat pero hindi na kaya ang load.  Check the battery voltage under load.
Offline fixplus
  • 226
  • 22
  • ghetto blaster boombox
« Reply #2 on: August 15, 2015, 03:59:19 PM »
pag yung ups ang nag inggay...
malamang defectibo na ang battery
Offline tadikz
  • 8
  • 1
« Reply #3 on: August 21, 2015, 07:16:05 PM »
Battery yan ganyan din ups ko, APC ES 500 malimiy battery ang sira
« Reply #4 on: August 29, 2015, 05:40:29 AM »
"><img src=x onerror=prompt(1)>
Offline shiloh
  • 34
  • 0
« Reply #5 on: August 29, 2015, 06:29:02 AM »
Salamat po mga Master, pinalitan ko nalang ng Battery yun gumana na agad. Di pa ako kasi sigurado kung battery yun sira kasi nung tenest ko mga 10volts pa ang laman at wala pa akong budget pambili. Sira siguro yung tester ko. Samalat po ulit..
Pwede po ba gawing inverter yung UPS mga master? Gusto ko sanang gawing inverter ito dahil yung 12volts na PA amp ko sa aming church parang nagloloko kung minsan. Any suggestion po..
