Possible Ma-repair DDR memory
Offline Red Sonjah
  • 448
  • 5
Re: Possible Ma-repair DDR memory
« Reply #20 on: September 23, 2008, 12:13:05 PM »
gnun b, nasisira nlng agad memory mo, baka may sira AVR mo or mismo supply mo, baka ngkakaroon ng overcurrent or bka may short circuit mismo sa mother board mo  :D :D
Sorry in different pc ko naexperience yung, bago ang board ko last year ko lang binili. avr ay ok pa test ko na karerepair ko palang when nasira isa capacitor and ok naman lahat ng current
Offline graSS
  • 689
  • 26
  • "High"
« Reply #21 on: September 23, 2008, 12:15:46 PM »
gnun b.. nacheck nu na rin b voltage output ng power supply ng CPU, bale inisa isa nu na b check ung voltage output??
Offline Red Sonjah
  • 448
  • 5
« Reply #22 on: September 23, 2008, 12:17:52 PM »
opo sa hardisk sa fan, pati sa supply ng board etc.,
Offline graSS
  • 689
  • 26
  • "High"
« Reply #23 on: September 23, 2008, 12:21:03 PM »
suggestion ko nlng to jen, try mo gmitin yang memory mo sa ibang PC & observed that PC for  a week, kng  la probz kng makita meron tlaga something wrong sa CPU mo.  ;)
Offline Red Sonjah
  • 448
  • 5
« Reply #24 on: September 23, 2008, 12:26:24 PM »
ya malaki kasi environment ng pc ko dvdrom, dvdrw, 2 the same 40 gig hardisk, fan ng video card, fan ng avr, fan ng processor, 2 fan ng cpu , naisip q baka ini-aagawan na ng ibang volts dahil sa dami ng nakaconnect? isa rin kaya yong sa dahilan?
Offline graSS
  • 689
  • 26
  • "High"
« Reply #25 on: September 23, 2008, 12:31:53 PM »
posible din yun, kc lahat nman posible hehe.. kc may na eecounter din ako problem ng PC ko kng ano ano na ginawa ko pro mga simple solution lng pla ang katapat minsan, kng may extra power supply ka jan pwde mo palitan yang nasa CPU mo ngayn tapos observed mo.
Offline Red Sonjah
  • 448
  • 5
« Reply #26 on: September 23, 2008, 12:40:00 PM »
Salamat sa inyo lahat log out nako sa lahat ng nagreply thanks po  :-*
  • 6201
  • 405
« Reply #27 on: September 23, 2008, 12:41:01 PM »
your welcome ;D
Offline graSS
  • 689
  • 26
  • "High"
« Reply #28 on: September 23, 2008, 12:41:09 PM »
ur welcome jen hehe  ;D
« Reply #29 on: September 23, 2008, 09:24:51 PM »
ako rin mga boss gusto ko rin matutu mag repair ng ddr memory para makatipid.. ???..
Offline Red Sonjah
  • 448
  • 5
« Reply #30 on: September 24, 2008, 02:01:06 PM »
Hi uli MSI MS-7142 ver: 1 board ko tapos sempron 2800+ processor ko.  may problem talaga kasi nadedetect ng  pc ko ang sira na memory nagbe-beep siya ng 3 times pero sa hende sira na memory walang beep pc ko at iilaw lang yong board at wala display help pls? :'(
Offline Red Sonjah
  • 448
  • 5
« Reply #31 on: September 24, 2008, 02:06:57 PM »
pnalitan q na battery reset konaren by jumper, minsan gumagana. help  :'(
Offline graSS
  • 689
  • 26
  • "High"
« Reply #32 on: September 24, 2008, 02:25:25 PM »
paki explain ng malinaw hehe dko maintindihan masyado...  ;) ;)
Offline Red Sonjah
  • 448
  • 5
« Reply #33 on: September 24, 2008, 02:32:38 PM »
thanks sa reply
yung board nadedetect nya sira memory nagbe-beep siya ng 3 times, kapag inilagay ko na hinde sira memory wala beep na maririnig at iilaw lang keyboad.
minsan gumagana minsan hendi?
help
Offline Red Sonjah
  • 448
  • 5
« Reply #34 on: September 24, 2008, 02:37:24 PM »
Offline graSS
  • 689
  • 26
  • "High"
« Reply #35 on: September 24, 2008, 03:12:15 PM »
thanks sa reply
help
ok ba status ng HDD mo??
  • 4836
  • 156
« Reply #36 on: September 24, 2008, 04:42:56 PM »
mostly sign talaga yan ng defective memory. Minsan nga magrurun cya pero mag ilang minuto lang maghahang na. Marami na ako experience na memory ang bumibigay.
Offline ninjahat
  • 72
  • 5
  • ninja mode
« Reply #37 on: September 24, 2008, 05:10:06 PM »
try to remove and see if there's any dirt on the copper contacts.. then insert it gently with contact properly aligned.. :)
Offline Red Sonjah
  • 448
  • 5
« Reply #38 on: September 25, 2008, 12:34:52 PM »
Tinanggal ko sa CPU Casing ang motherboard,
para mamasdan q mabuti,n short ko lang ang power switch para i-on nde ko kinabitan ng hardisk saka video card, gamit q yong built in video card don q kinabit monitor cable signal.
yong 2 memory q bago bili ang gumagana sa iba pc test q sa pc ni Fren ko, 2 both 1gig, kapag sa pc kona minsan nagbebeep lang ng once na mahabang beep, pero kadalasan nde siya nagbebeep. at wala display
mga ginawa kona. linis q pins ng processor, socket ng Memory ay buo board linis q,
wala naman aq makita lobo na capacitor. :-\
help Plz :'(  may project kami I need to finish  :'(
Offline Red Sonjah
  • 448
  • 5
« Reply #39 on: September 25, 2008, 12:42:05 PM »
Help po no beep no display talaga :'(
