DNY40w MKII your ideas needed!
Offline <<<<<------
  • 1025
  • 38
Re: DNY40w MKII your ideas needed!
« Reply #280 on: May 18, 2017, 06:09:25 PM »
na try ko class d ni JlesterP ok ang tunog.
  • 11484
  • 872
« Reply #281 on: May 18, 2017, 06:32:17 PM »
meron din si Dandy, okey din ang tunog....
meron din si Gerry Morales na classD, sa cebu meron na rin na gumagawa, nasa FB sila...
Offline <<<<<------
  • 1025
  • 38
« Reply #282 on: June 01, 2017, 09:16:48 PM »
almost perfect emitter follower/cascode combo :D
60V/usec, triple zero at 50kHz  :)
Offline <<<<<------
  • 1025
  • 38
« Reply #283 on: June 01, 2017, 10:37:56 PM »
run to the max
Offline Abe T
  • 1942
  • 236
  • the future belongs to the curious...
« Reply #284 on: June 02, 2017, 11:00:11 AM »
Guys i-lock ko muna topic na'to,  yung "DNY" term yata refers to Sir Danny, I was under the impression na eLab DIY amp yun...with respect to the original designer, mukhang exagerrated yung thread ko dapat yata iniba ko na lang yung title.  :)
Fast rev sis, create ka na lang uli ng thread mo at duon na lang natin silipin mga sim works mo.   ;)
Ciao!
I have no special talents, I am only passionately curious
Albert Einstein
...agree 100%. Throw your ideas at the wall, and see what actually sticks, as one person put it!
-Gnobuddy
