panasonis tv...TC-21FJ30P...pakitulong mga masters.
Offline VICOY
  • 658
  • 73
« on: February 05, 2014, 02:35:05 PM »
Good pm mga ka-elab pls. help naka standby mode itong ginagawa kong tv.
here are the major parts:
reg..-STR W6754
HOT -C5902
Vertical ic-AN5522
Triple video amp out-TDA6107
Initial na nagawa:
-replace vertical Ic (busted)
-Resolder
-replace direct Ecaps both primary and secondary
-check B+...8v while on standby....135v during start up then balik stand by.
PLS.....mga masters give advice.....ty.
Offline saipper
  • 2463
  • 288
Re: panasonis tv...TC-21FJ30P...pakitulong mga masters.
« Reply #1 on: February 05, 2014, 08:36:37 PM »
split sec lang ba ang pag bagsak ng B+
paki hang muna hot neto tapos check B+ kung babagsak parin.
pag bumabagsak parin, isolate mo muna tuner.
pag ndi, nag poprotect ang unit.
1.) Respect each and every member, either the newly registered or old members.
  *Avoid making insults
  *Trolling or any insult resulting to a fight, will result to immediate warning banning of members.
Offline VICOY
  • 658
  • 73
« Reply #2 on: February 06, 2014, 10:20:38 AM »
Hang ko na po HOT....hindi na nag standby...B+ 130-135 vdc baba taas normal b ito master saipper?
-Ikinabit ko ulit HOT standby ulit....palagay ko nagpoprotect.
-May na notice po ako na may charge ung main Ecap pag off ang unit..Ano kaya ang dahilan master??need your advice.
good morning and ty in advance.
Offline saipper
  • 2463
  • 288
« Reply #3 on: February 06, 2014, 11:55:35 AM »
Ndi normal yan.
kailangan mag normal muna ang B+ mo kaya hang mo muna hot mo para safe.
baka may nakaligtaan kang capacitor na ndi mo napalitan sa PSU. check mo ulit. damay mo na rin resistor, diode sa paligid.
Offline VICOY
  • 658
  • 73
« Reply #4 on: February 06, 2014, 01:05:50 PM »
...thanks master.Isa isahin ko mga components sa PSU area.Update ko mamaya.
Offline VICOY
  • 658
  • 73
« Reply #5 on: February 06, 2014, 07:06:49 PM »
Good eve....master saipper..steady na sa 135vdc ung B+ naka hang pa rin ang HOT.....nagpalit ako ng reg. kasi wala akong makitang defective components.,pero may charge pa rin main Ecap maski off na ang unit.,feedback circuit kaya???.pls. master huwag ka sanang bumitaw sa pag-alalay. ty.
Offline saipper
  • 2463
  • 288
« Reply #6 on: February 06, 2014, 10:15:47 PM »
paanong off ang ginawa mo? unplug ba mismo sa power source?
Offline VICOY
  • 658
  • 73
« Reply #7 on: February 06, 2014, 11:27:51 PM »
naka unplug unit... sinukat ko mga 310vdc.
Offline saipper
  • 2463
  • 288
« Reply #8 on: February 07, 2014, 09:53:13 AM »
kung normal na B+ try mo ikabit ang hot at testingin mo kung babagsak parin.
nagpalit ka na ba ng mga ecap sa pri at sec? palitan mo na rin kahit good cyang tingnan.
huling option is ipa check mo fbt para mabawasan ang duda.
Offline VICOY
  • 658
  • 73
« Reply #9 on: February 07, 2014, 11:08:13 AM »
update mga masters....esp. master saipper....uma-andar na po ang tv under observation.
dagdag na ginawa:
-replace r850 sec. supply....change value.
-replace r560 puntang yoke....open.
-change direct 3 ecaps sa sec, supply
....thanks sa iyo master saipper +1 point ka.
Offline saipper
  • 2463
  • 288
« Reply #10 on: February 07, 2014, 06:24:15 PM »
congrats.
tingin ko ok na yan.
bigay mo na sa tumer para pera na :)
« Reply #11 on: January 08, 2020, 01:56:43 PM »
sa nakawa nito ano ang value ng d1132 malapit smd jungle basag kasi at ang r558 sunog kasi resistor papuntang pin 2 fbt..salamat
Offline hackerz
  • 595
  • 5
    • operamini
« Reply #12 on: July 14, 2020, 04:03:05 PM »
COngrats ....may pang kape sis
god is good all the time
