Transformer design ang Formulas
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« on: October 31, 2019, 11:53:20 AM »
See here and comments na lang from other/s and master/s
https://en.wikibooks.org/wiki/Electronics/Transformer_Design
Simpler formulae
A shorter formula for the core area (a) and the turns per volt (T) can be derived from the long voltage formula by multiplying, rearranging, and dividing out. This is used if one wants to design a transformer using a sine wave, at a fixed flux density, and frequency. Below is the short formulas for core areas in square inches having a flux density of 12 kilogauss at 60 Hz (see note 2):
    a = 0.1725 sqrt( P )
    T = 4.85 / a
and for 12 kilogauss at 50 Hz:
    a = 0.206 sqrt (P )
    T = 5.82 / a
a - area of core
Erms = 4.44 f N B a 10-8
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
FISH
Offline congressman
  • 4772
  • 324
Re: Transformer design ang Formulas
« Reply #3 on: October 31, 2019, 11:24:27 PM »
anong proseso para makumpirma yung amperes ng secondary ng transformer build.
looking for confirmation at hindi computation. paki post kung paano gawin. t.y. sa magreply
ginaya ko lang nabasa ko sa kabila.
Peace!
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #4 on: November 01, 2019, 08:41:36 AM »
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #5 on: November 01, 2019, 08:44:27 AM »
FISH
Offline Johannah Aleksandria
  • 3616
  • 197
  • Make it simple
« Reply #6 on: November 01, 2019, 09:01:18 AM »
Pinagsama ko yung transformer calculator ni Silvio Klaic at isang program ni Rod Elliot. Napakabilis. EI core lang naman.
Makikita na yung size ng wire at input/output voltage at power sa program ni Klaic, pero gusto ko yung calculator sa # of turns sa program ni Rod Elliot. Size of core lang ang basehan sa dalawang calculator na ito.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #7 on: November 01, 2019, 09:20:20 AM »
Hinahanap ko iyong core VA rating ayun sa tongue area derivation. Iba iba kasi ang unit na ginagamit nila. At kababalik ko lang uli sa papel kaya windang na uli. Kung dati ng windang ngayon mas malala na.  ;D   Ngayon trying to derive the formula to get sa mga ginagamit na formula dito.
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #8 on: November 01, 2019, 09:25:04 AM »
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #9 on: November 01, 2019, 12:20:21 PM »
Lets compare muna sa ibat ibang source credits sa lahat na para sa kanya kanya.
https://www.youtube.com/watch?v=zz7jqW4Nwoc
P= (5.6A)2
turn/volt = 10,000  / 28.65 * CA in square inch * f
P - power
A - area of core
f- frequency
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #10 on: November 01, 2019, 12:28:15 PM »
Additional
https://www.elprocus.com/transformer-design/
catch up na ninyo mga sir baka mawala rin iyan.
window area but in cm
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #11 on: November 01, 2019, 12:37:47 PM »
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #12 on: November 01, 2019, 01:16:18 PM »
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #13 on: November 02, 2019, 07:33:19 PM »
Isang bagsak lang, credit sa may-ari.
para sa hindi pihikan. Kung gusto ninyo pang laruin ok lang basta malapit sa katutuhanan.   ::) >:( ;)
Simpler formulae
    T = 4.85 / a
    a = 0.206 sqrt (P )
    T = 5.82 / a
a - area of core
Erms = 4.44 f N B a 10-8 hula naman kung ano unit neto............. ::)
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #15 on: November 02, 2019, 07:47:06 PM »
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #16 on: November 02, 2019, 08:00:56 PM »
Isa na lang.
EMF equation.
https://slideplayer.com/slide/6045459/
share na mga sir/maam ate kuya and masters.. :-* :'(
FISH
Offline Mhavskie
  • 1407
  • 114
  • మార్విన్
« Reply #17 on: November 03, 2019, 02:07:49 AM »
Simpler formulae
    T = 4.85 / a
    a = 0.206 sqrt (P )
    T = 5.82 / a
a - area of core
yung formula sa photo matatagpuan din to sa RDH4 kalimitan inches ito, sa metric hindi ko kabisado,. another site na pwede puntahan yung kay ludens at turneraudio,. yung flux density need din ng discussion.
In this world, whenever there is light, there are also shadows. As long as the concept of winners exists, there must also be losers. The selfish desire of wanting to maintain peace causes wars and hatred is born to protect love.
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #18 on: November 03, 2019, 06:36:23 PM »
Ang alam kung base unit niyan ay weber/square meter conversion lang nangyayari at material grade ang laruan ng mga pogi.  ;D
FISH
Offline >>>^żżż^<<<
  • 13845
  • 706
  • żżż
« Reply #19 on: November 03, 2019, 07:34:07 PM »
E=4.44 (F)(N)(PHI)       base formula para sa sinosoid waveform.
Pmax =BmaxA   where A is the area of core.  in square unit.
kaya subtituting (P)phi para maexpand at lumabas ang betamax at ang bitamina "A" kaya nagiging
E=4.44 (F)(N)(Bmax)A  volts where betamax ay 1 weber per square meter. That is almost 65000 lines of force per square inch naman sa ibang unit. Kaya nagkakameron ng 10-8. O 1 gauss or base where betamax ay 1 tesla that is also equal to 1 weber per square m.  Karaniwan naman ginagamit na value ay malapit sa isang tesla.  Pinakamataas na nakuha sa ibang material ay 4. Pero hindi pa para sa transformer ngayon.
FISH
