Transformer Calculator!
Re: Transformer Calculator!
« Reply #100 on: May 02, 2014, 06:45:50 PM »
what do you mean by accurate? any will work naman as long
as you don't use high T(Tesla), which is over 1 Tesla,
for deeco Irons i use 0.6 T average...
0.6 tesla sir, for example po ba pag me 2000watts n secondary wattage dapat imultiply sa 0.6 at idadagdag sa 2000 at magiging 3200w na dahil sa core loss sir?
Offline SannRock
  • 14
  • 0
« Reply #101 on: September 07, 2014, 05:03:32 PM »
thanks! subscribing..........
  • 11484
  • 872
« Reply #102 on: October 06, 2014, 10:22:53 AM »
power factor yan...not all primary volt amperes are useable in the secondary, there is an energy component..
« Reply #103 on: January 27, 2015, 10:13:10 PM »
sir tony patulong po ako, gusto ko gumawa ng transformer para sa diy amp ko, ang requirements ko po ay 220v primary 55-0-55 20amps,18-0-18 2amps secondary,anu po magnet wire size kelangan ko? ilang turns po sa primary at secondary? anung sucat po ng ei core ggamitin ko? anu po core area? sa deeco po ako bibili ng mga materials, salamat po
  • 11484
  • 872
« Reply #104 on: January 28, 2015, 07:47:12 AM »
i have posted a lot of information already here, please read and learn on your own....
Offline Mr.W
  • 79
  • 0
« Reply #105 on: February 15, 2016, 08:53:31 PM »
Hi po mga MASTERS :) Miron dn po bang transistor calculator?tanong lng po :)  ;D
  • 11484
  • 872
« Reply #106 on: February 16, 2016, 06:31:05 AM »
meron nyan, igoogle mo lang, saka topic for another thread, not this one...')
