nonterminating program...
Offline n
  • 91
  • 4
  • prioritize your priorities!
« on: February 28, 2008, 12:36:46 PM »
 i want to create a turbo c program that would only terminate (go back to its source code) when i entered a certain letter/number.... how do i make it sir? please help...
example:
in the running program:
menu
(a) i love you
(b) i hate you
(c) exit
kapag ni run ko na po iyong program (ctrl+F9) yan po iyong makikita ko sa screen tapos kapag pinindot ko iyong "a" ipiprint niya eh "i love you" tapos babalik ulit dun sa may menu at pag pinindot ko ulit iyong "a" print ulit "i love you" balik sa menu, pindot "b" print "i hate you" tapos pag pindot "c" balik na ako sa edit window... gets niyo naman po di ba?
please help me... thanks po.. :) :) :)
basa basa basa
Offline zer0w1ng
  • 2190
  • 308
    • The Cebuano Geek
Re: nonterminating program...
« Reply #1 on: February 28, 2008, 01:52:22 PM »
Put a getch() before the end.
This will pause your program before quitting and waits for a key to be pressed.
The Cebuano Geek
Offline simplywel
  • 38
  • 3
« Reply #2 on: February 28, 2008, 01:57:29 PM »
mas madali kapag gumawa ka muna ng flow chart
then write mo na yung codes..
People are just people, it's what they do which makes them good or bad
Offline kamote
  • 126
  • 4
« Reply #3 on: February 28, 2008, 02:55:00 PM »
ALT F5 para makita mo yung display screen :P
pero mas maganda ang getche();
  • 6201
  • 405
« Reply #4 on: February 28, 2008, 05:15:25 PM »
example:
menu
(a) i love you
(b) i hate you
(c) exit
try this
int main()
char x;
do
  // dito mo ipasok ang code mo
  x=getch();
  }while(x!='0'); // habang di mo pinipindot ang 0, di ka pa rin mag eexit
return 0;
Offline n
  • 91
  • 4
« Reply #5 on: February 29, 2008, 12:52:41 PM »
try this
int main()
char x;
do
  x=getch();
return 0;
thanks po sir sevenstring... ang galing mo talaga... hehehe... ayos na.... hehehe!!!! ;D ;D ;D ;D
basa basa basa
