PC MotherBoard Repair
Offline Woots29
  • 5493
  • 348
  • asan si mojacko?
    • Woots Page
Re: PC MotherBoard Repair
« Reply #20 on: November 15, 2008, 08:27:17 AM »
opo surface mount.
WootsPC2 Videos  Woots Page
« Reply #21 on: November 15, 2008, 08:33:55 AM »
Offline THXneo
  • 698
  • 45
  • DJ, Home Theater Fanatic
« Reply #22 on: November 15, 2008, 09:30:53 AM »
MOBO problem:
pag walang RAM na naka saksak, no beeping sound.. pag may nilagay ka, wala pa din, at walang display sa monitor.. naka steady lang yung RED LED ng CPU, walang beeping sound talaga... pinacheck ko sa tech, sira na nga daw yung mobo... anong tingin niyo?
ung cpu b ok?
kc pag sira din cpu ganyan din nangyayari.
kng ok nman cpu.
try mo "liguan technique" with JOY ;D
bka kulang lng sa ligo.hehehhe
More to Lose by Seona Dancing
« Reply #23 on: November 15, 2008, 11:48:27 AM »
ung cpu b ok?
kng ok nman cpu.
panong sira din yung CPU sir?
na isolate ko na yung PSU at HDD, ok naman, nagana sa isa ko pang cpu, yung fan ng processor, gumagana naman, sabi nung tech dito, bihira namang masira ang processor...
sureball ba yung ligo technique ser? wala naman halos alikabok yung mobo eh...
nga pala... bago mangyari yung sira sa mobo... dati, nabubuksan pa yung CPU, may display sa monitor, pero hindi na nagboboot papuntang winXP, evan makapunta ng CMOS settings, ayaw din, at naghang na... tapos nung nirestart, ayun wala na ulit na display sa monitor... nireplaced ko yung CMOS battery, ni reset ko nga din... no effect.... basta sa ibang forums na puro foreigner ang forumers, sabi nila, pag hindi daw talaga nagbeep yugn CPU na walang RAM na naka install, wala na daw yung mobo...
  • 6201
  • 405
« Reply #24 on: November 15, 2008, 11:56:58 AM »
I use the joy technique as a last resort... malaki ang naitulong sa akin nyan for pc repair. pero kung nasa warranty pa, pa warranty na lang...
Offline graSS
  • 689
  • 26
  • "High"
« Reply #25 on: November 15, 2008, 12:05:09 PM »
I found this one in the net. Although it's not an actual repair guide but it can help for familiarization purposes. Have a look:
http://www.simulationexams.com/tutorials/aplus/core/motherboard.htm
« Reply #26 on: November 15, 2008, 12:08:17 PM »
wala ng warranty sir, di na umabot...
Offline Red Sonjah
  • 448
  • 5
Offline Woots29
  • 5493
  • 348
  • asan si mojacko?
    • Woots Page
« Reply #28 on: November 15, 2008, 12:21:36 PM »
naku hindi ko lang alam, aling fuse ba? yung mga nakikita sa ibat ibang device? or SMT din?
ung kulay green ung SMT fuse
« Reply #29 on: November 15, 2008, 12:24:38 PM »
sige ill check pag may time, i'll post pics din... thanks!
« Reply #30 on: November 18, 2008, 12:30:13 PM »
yan ba yung part na lilinisin ng JOy? plus tubig yung solution no? tapos pwedeng toothbrush ang gamitin?
makakatulong din ba kung magreresolder ako ng capacitors dun sa mobo?
Offline neutron
  • 333
  • 15
« Reply #31 on: November 18, 2008, 01:56:15 PM »
you could also try those Debug Cards to indicate anong area ang may tama.......tapos ilublub sa Joy!  ;D
« Reply #32 on: November 18, 2008, 02:22:58 PM »
ano yung mga debug cards? nalinis ko na yung surface ng mobo, joy tapos toothbrush, hangang sa mawala na yung bula, pinapatuyo ko nalang, bukas ko pa pagaganahin...
Offline rurikdgreat
  • 357
  • 11
« Reply #33 on: November 18, 2008, 02:57:50 PM »
hindi mo inanlawan? baka bumaho hehehe joke lang. pero dapat inanlawan mo, saka pati component side nililinis din. mga 2 days na patuyo pwede rin i-blow dry.  ;D ;D ;D
Life's too short...... call CQ!
A HAM will always be a HAM.
Offline Dennis
  • 155
  • 30
« Reply #34 on: November 18, 2008, 03:02:16 PM »
ano yan bard mo msi k8 yung V-Class?
Sa experince ko madali talaga masira msi, kadalasan sira jan ay wala display at nde madetect ang memory, kapag check mo naman memory ok pa. mahilig rin yan sumira ng memory sa video card.
hindi po ako naninira ng brand ah. Base lang po sa experience ko
1-2 years lang ang pinakamahaba gamit ko dyan sa msi. Pero yung ECS duron na processor ko na 1.1ghz kahit napakaluma na at kalawangin na mga socket nya ay ok parin
Failure is not defeated, Unless you stop trying
OmegaByteŽ, ExplicitmindŽ, DMSoftwareŽ
« Reply #35 on: November 18, 2008, 03:16:42 PM »
tama ka bro, no display nga eh... marerevive pa kaya yan? hehe
Offline Dennis
  • 155
  • 30
« Reply #36 on: November 18, 2008, 03:24:14 PM »
Sundin mo mga post nila dito. nun una akala ko mga mga sira nya e yung memory socket madumi o kaya memory pero, mahirap kasi idetect talaga sira dahil minsan gumagana yan tapos babalik uli sa dati. capacitor try mo palitan lahat, tingan morin mga pin ng IC baka may nagshorted.
pero teka tanong ko muna ito. nag overclock kaba? nakalagay kasi yung sa device driver nyan
« Reply #37 on: November 18, 2008, 03:28:51 PM »
di ko pinakialamanan yung clock speed ng cpu, as of now, nalinis na yung surface, di ko pa nalilinis yugn ram slots...
di naman bloated yung mga capacitor, talagang papalitan ko na? ang alam ko pang matagalan ang electrolytic capacitors eh... cge last resort ko ang pagpapalit ng caps
« Reply #38 on: November 18, 2008, 03:31:36 PM »
inanlawan naman, hangang wala ng bula.. di ko na binaklas yugn processor, ok lang ba yun? sige pati component side, linisin na din..
Offline Red Sonjah
  • 448
  • 5
« Reply #39 on: November 18, 2008, 03:42:20 PM »
mas maganda if tanggalin mo processor saka gamitin mo ung sipelyo mo sa paa, bilang brush ;)
