PECE application and interview
« on: April 05, 2009, 11:51:01 AM »
To all who are aspiring to become PECE here is your guide...
Comply the necessary requirements at saka i-file sa PRC or attend IECEP activities where they assist PECE applications (Don't forget to bring your documents).
Eto ang mga requirements:
   1. Valid PRC ID as Electronics Engineer or Certificate as Electronics Engineer
   2. Valid IECEP ID or Certificate of Membership in good standing from IECEP
   3. Certified experience record of active self-practice and/or employment either in gov’t. service or in private sector, in the format to be prescribed by the Board, indicating the inclusive dates, companies worked for, description of specific responsibilities, relevant accomplishments and name, position of immediate supervisor for a period of at least seven (7) years (inclusive and/or aggregate), at least two(2) years of which are in responsible charge of significant engineering work, from the date applicant took his/her oath as and Electronics and Communications Engineers or Electronics Engineer.
   4. Three (3) certification signed by three (3) PECE attesting that the experience record submitted by the applicant is factual (not needed for those who have been registered and licensed as ECE under R.A. 5734, for at least seven (7) years.
   5. Original NBI Clearance (Private Sector)
   6. Original Ombudsman Clearance (for those in gov’t service)
TIPs to pass the interview:
1. Kilalanin ang Board of ECE (Sila ang huhusga nang kapalaran ninyo para maging PECE)
      Eto sila:
                 1. SYLVIA ICASIANO-MARCELO, Chairman
                 2. NESTOR C. DACANAY, Member
                 3. JOEL B. BAJADOR, Member
2. Eto ang mga basehan nila sa pag-rate sayo:
          Subjects: 1. Work Experience
                        2. Punctuality
                        3. Accuracy in Answering Technical Questions
                        4. Composure and Confidence
                        5. Verbal Ability
3. Kung may pagkakataon, pili-in ang mag-interview sayo:
        - Kung si Engr. Marcelo ang nag-interview sayo, life will be difficult (you have to prove ur self na worthy ka to become PECE)
        - Kung si Engr. DACANAY ang nag-interview sayo, life will be less difficult
        - Kung si Engr. Bajador ang nag-interview sayo, life will be easy (may advantage sa mga galing Bisaya na PECE applicants)
4. Additional tips
       -  Sa ngayon hindi pa masyadong strict ang screening especially pagmabait ang nag-interview sayo. Even purely teaching experience ka lang at walang industry experience and do not know how to draw Electronics Plan papasa ka pa ngayon.
       - Pag may IECEP activity attend ka para makilala ka.
       - Pag may nabalitaan ka na meeting para sa creation ng bagong IECEP chapter sa lugar nyo umatend ka at tumakbo bilang isang IECEP officer. Pagnag-apply ka for PECE smooth as silk ang chance mo na makapasa sa interview dahil isa kang officer ng iecep chapter.
       - Significant engineering work hindi tinitingnan kung IECEP officer ka or mabait ang nag-interview sayo. Basta naka 7 years experience may chance na.
       - i-grab nyo na ang oppurtunity ngayon dahil hindi pa nagbabago ang guidelines ng requirements for PECE. Wala pang thesis na ni-re-require kagaya ng sa PEE at PME. Basta naka 7 years experience ka pwede na.
I hope mga kapatid makapagbigay tulong ito sa inyo na gustong mag apply na maging PECE para dumami tayo....
Offline Google
  • 1377
  • 20
Re: PECE appilication and interview
« Reply #1 on: April 05, 2009, 11:59:45 AM »
dapat ganyan na lang ang gawin para maging registered ECE para mas credible...
tutal onti lang din papasa dyan eh
Offline mArKhAo
  • 2284
  • 70
  • point and shoot
« Reply #2 on: April 05, 2009, 12:06:49 PM »
wait natin si sir.wilfredo, baka may maidagdag pa xa na tip
Offline Google
  • 1377
  • 20
« Reply #3 on: April 05, 2009, 12:09:14 PM »
oo nga ;D ;D
« Reply #4 on: April 05, 2009, 12:16:19 PM »
      Eto sila:
                        2. Punctuality
                        5. Verbal Ability
4. Additional tips
Si Sir Bajador sya nag-interview sa akin. Simple lang mga tanong at titingnan lng experience... Thanks Sir!
Offline Google
  • 1377
  • 20
« Reply #5 on: April 05, 2009, 12:21:09 PM »
Si Sir Bajador sya nag-interview sa akin. Simple lang...
sir ano sinabi at mga tinanong niya sa iyo? share nmn po ninyo :)
« Reply #6 on: April 05, 2009, 12:23:16 PM »
Nabasa ko post ni sir wilfredo baka pang Professional Electronics Technician lang ang sa kanya...
Offline Google
  • 1377
  • 20
« Reply #7 on: April 05, 2009, 12:30:09 PM »
mayroon din about sa PECE .... ewan ko baka siya yung representative ng ECE board members dito sa elab ;D ;D ;D ;D
diba sis markhao ? ;D ;D
« Reply #8 on: April 05, 2009, 12:34:00 PM »
I cannot give the exact question ha kasi baka magkaroon ng issue ng leakage sa PECE. Hehehe.... Konting tanong about sa experience at tinitingnan nya mga authenticated documents na nasubmit yun lng. According to others depende daw kasi kung kanino mapunta yung documents mo for interview. So far di masyadong strict (feeling ko lng ito ha. Baka magbago pagdumami na PECE). Baka yung reason na konti lng na re-release kasi konti din yung nag-aapply or naka comply ng requirements. Kaya tama yung thread starter i-grab nyo na na makahabol kayo ngayon. Siguro hindi pa umabot ng 200 ang PECE sa buong Pilipinas.
Offline ,,V, (@_@) ,V,,
  • 219
  • 26
« Reply #9 on: April 05, 2009, 12:42:35 PM »
Kpag nkagraduate ng c0llege, bachelor(BS) un n0h? Pan0 maging MS? Ung sun0d ba sa MS eh PECE???
Wla lng!
« Reply #10 on: April 05, 2009, 12:42:48 PM »
Yung kay sir wilfredo kasi parang involved sya talaga sa screening ng professional Electronics Technician ayon sa post nya at nagbibigay sya info tungkol dito. Makakatulong naman para sa mga gustong maging Electronics Technician :)
« Reply #11 on: April 05, 2009, 12:50:21 PM »
Pagnaka gradweyt BS. Depende na sayo kung mag MS ka. Kung ECE ka na may 7 years experience pwede ka nang mag-apply for PECE kahit walang masteral degree. Now kung between 5 and 7 years experience ka pa lang you need three(3) certification from three(3) PECEs para makapag-apply ka for PECE. Sa CDO daw tag Php300.00 per certification pag nag certify ang PECE. Vouching fee daw :)
Kaya maka extra income ka sa PECE. Lalo na pag may mga Electronics Plan na pipirmahan. Sana maging fully implemented na yung Electronics Permit sa mga LGU. Nasa batas na at tinuturo sa ECE laws pero ang katotohanan 98% ng LGU hindi pa ini-implement ang batas para sa atin. Pilipinas talaga oo...
Offline Admin
  • 2027
  • 174
    • Elab.PH
Re: PECE application and interview
« Reply #12 on: April 05, 2009, 12:57:34 PM »
how bout me?.. i have never been a member of IECEP ever since nakapasa ako sa board exam.. hindi kasi ako nagbayad nung membership fee sa IECEP pagkakuha ko ng lisensiya, hindi rin ako nag-paregister..
« Reply #13 on: April 05, 2009, 01:12:07 PM »
Pwede ka pa rin maging PECE bro. P3,500 ang i-charge ng IECEP sayo (350 x 10years). Pa confirm mo lang sa taga IECEP kung ito pa yung formula nila for back dues... Then Pa convert mo sa Electronics Engineer then later pagnakuha mo ID pa upgrade ka for PECE. May mga case na kagaya mo.
Offline Admin
  • 2027
  • 174
    • Elab.PH
« Reply #14 on: April 05, 2009, 01:17:02 PM »
ok thanks for the info hehehe..
Offline alyas
  • 3118
  • 211
« Reply #15 on: April 05, 2009, 02:06:06 PM »
Saan ba ofice ng IECEP sa Makati?  Dati alam ko sa Tordesillas nung una akong nagparenew ng license.  Hindi pa naman lampas 10 years na expired yung license ko.  Pwede pa ba ma-upgrade to PECE?
« Reply #16 on: April 05, 2009, 02:12:33 PM »
INSTITUTE OF ELECTRONICS ENGINEERS OF THE PHILS INC
   7th Floor, Unit 712 Cityland Shaw Tower Shaw Blvd.,
                Cor Saint Francis St., Mandaluyong City
Yup. Pwedeng-pwede ma upgrade to PECE basta comply mo yung requirements at magbayad ka sa IECEP para meron kang "Certificate in Good Standing". Baka luma pa yan ECE under RA5734. Ipa-convert mo muna sa ECE under RA9292 then upgrade to PECE.
Note: Pagnag-apply ka for PECE hindi ka makalusot sa IECEP. Magbabayad ka ng back dues coz hahanapin ng Board ang Certificate in good Standing mo.
Offline Google
  • 1377
  • 20
« Reply #17 on: April 05, 2009, 05:47:15 PM »
anong mga electronics permit ang pipirmahan?? for example may isang ECE ang may design ng isang amplifier? yung design ba ng  amplifier ay yung pipirmahan ng isang PECE? ??? ??? ???
  • 219
  • 26
« Reply #18 on: April 05, 2009, 06:07:57 PM »
My advantage b kung nagmasteral ka muna bago magPECE compared dun s BS lng?
Wla lng!
Offline ef - el - ay - pee
  • 678
  • 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #19 on: April 05, 2009, 06:41:01 PM »
feeling ko concurrent sila, diba para maging PECE ka eh 5-7 years kang practicing ECE, that time cguro nagmamasters ka na...
